XPEnology in PC - Change Serial Number
ema
20 answers to this question
Change the boot loader by adding parameters to the kernel and comment cksum, vender and hw_model.
title SYNOLOGY
       root (hd0,1)
#       cksum /grub_cksum.syno
#       vender /vender show
#       hw_model
       kernel /zImage root=/dev/md0 ihd_num=0 netif_num=2 syno_hw_version=DS3612xs mac1=00113208d68a mac2=00113208d68b mac3=004d9469c492 mac4=004d9469c493 sn=B3J4N00001
       initrd /rd.gz
Or hexedit the synoboot.
Had a quick look at hex editing... trialed on VBOX image only as getting late....
Seems a quick change (only for the last number in the serial) that works with the check sum is that the number after the serial number needs to be 1 higher.
e.g. if your serial is B3J4N00000 then the version in the file will need to be B3J4N000001
So, if you want your serial to be B3J4N00008 then the version in the file needs to be B3J4N000089
...not tried editing the IMG file yet, but assume the same will work.....
hi!
i just have made the change, it works great.
how to :
connect to your xpesyno via putty as ROOT.
>mount /dev/sda1 /mnt
>exit
Connect to your xpesyno via WINCSP as root.
browse to /mnt/boot/grub/
edit menu.lst
and modify mac and serial as you want. if there is other title synology chapter modify them too
title SYNOLOGY
root (hd0,1)
# hw_model
kernel /zImage root=/dev/md0 ihd_num=0 netif_num=2 syno_hw_version=DS3612xs mac1=00113208d68b mac2=00113208d68c mac3=004d9469c492 mac4=004d9469c493 sn=B3J4N00011
initrd /rd.gz
regards
1. I'm a little unclear about what's being proposed here. Does this hack essentially mean that once the system is up and running I can change the serial no and/or MAC address without having to change the checksum file?
2. The mount command suggested by patmtp35 gives an error stating that there is no such device. I've checked on my real Syno box (DS210j) and get the same error trying to mount /dev/sda1. However commands like fdisk -l show that there's a partition called /dev/sda1 but it doesn't contain a valid partition table. (And the same message on my DS210j.)
fdisk -l /dev/sda1
Disk /dev/sda1: 2550 MB, 2550005760 bytes
255 heads, 63 sectors/track, 310 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk /dev/sda1 doesn't contain a valid partition table
Any ideas?
regards
I want to change the MAC address & serial number but can't work out how to mount the img file so that I can edit it, could someone please give me clear instructions on how to do this Please.
Many thanks
where do reside your boot image? if in usb sttick, it's simpe, boot nas, take out usb stick at the end of the boot, put the stick onto usb in a linux-box, mount image and edit.
Hi Aigor, thanks for your reply. I'm running Debian 6 in a VM where I have the img file also. to mount the img file I've run the following to find the sextors:
# fdisk -lu SynoBoot_3612xs_4.1++.img
You must set cylinders.
You can do this from the extra functions menu.
Disk SynoBoot_3612xs_4.1++.img: 0 MB, 0 bytes
255 heads, 63 sectors/track, 0 cylinders, total 0 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0xf6eba356
Device Boot Start End Blocks Id System
SynoBoot_3612xs_4.1++.img1 * 63 32129 16033+ 83 Linux
SynoBoot_3612xs_4.1++.img2 32130 224909 96390 83 Linux
I've then run:
# mount -t auto -o loop,ro,offset=61 SynoBoot_3612xs_4.1++.img.img /mnt/dsm
but get an error saying I must specify a filesystem type.
What am I doing wrong!
Hi, you have to use parted to know exactly offset of your image
[root@centos6 dude]# parted synoboot_microserver.img
GNU Parted 2.1
Using /home/dude/synoboot_microserver.img
Welcome to GNU Parted! Type 'help' to view a list of commands.
(parted) u
Unit?  [compact]? b
(parted) p
Model:  (file)
Disk /home/dude/synoboot_microserver.img: 394817536B
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Number  Start      End         Size       Type     File system  Flags
1      32256B     16450559B   16418304B  primary  ext2         boot
2      16450560B  115153919B  98703360B  primary  ext2
(parted)
at this time copy the number of start and run mount
[root@centos6 dude]# mount -o loop,offset=32256 synoboot_microserver.img /mnt/syno_root/
Go inside of mountpoint/boot/grub/ and edit grub.conf
[root@centos6 dude]# cd /mnt/syno_root/boot/grub/
[root@centos6 grub]# vi grub.conf
#serial --unit=0 --speed=115200
#terminal serial
default 1
timeout 4
hiddenmenu
fallback 0
title SYNOLOGY_1
       root (hd0,0)
       hw_model
       kernel /zImage root=/dev/md0 ihd_num=5 netif_num=1 syno_hw_version=RS3612xs
       initrd /rd.gz
title SYNOLOGY_2
       root (hd0,1)
       vender /vender
       hw_model
       initrd /rd.gz
This view comes from my image that run on N40L hp microserver
Around the forum you will see an example with serial number, if you have more thet one syno on the same network, it's' more safe add mac-address in grub boot command line
kernel /zImage root=/dev/md0 ihd_num=5 netif_num=1 syno_hw_version=RS3612xs mac1=macaddress sn=BJ0000000
hi!
how to :
>exit
edit menu.lst
title SYNOLOGY
root (hd0,1)
# hw_model
initrd /rd.gz
regards
thx , it works ...
Hi all
this topic is very interesting. I have tried to follow it and do the changes but I have not had any success:-
- My setup is using a VM with ESXi 5.5
- I have version 4.2
- I can not find the Vendor file on the VM machine
- when I try to mount sda1 I get an error that is doesn't exist
- I noticed that all mounted drives are md0, md1 and md2
- if I mount md0 I get the root drive which contains all the linux files but no vendor file or any of the files mentioned.
- I added the mac1=xxxxxxxxxx and sn=xxxxxxxxxxxx to the boot command manually but that did not change anything.
I need help please.
Answer this question...
