justgosh Posted August 27, 2014 Share #1 Posted August 27, 2014 I'm running DSM 4.3 build 3810++ (repack v1.0), but I get the feeling this might help out others So, I've been running the build, testing, for several months on 2 systems. One seems to occasionally have several services crash while the other has been rock solid until several days ago. Internal Server Error The server encountered an internal error or misconfiguration and was unable to complete your request. Please contact the server administrator, admin and inform them of the time the error occurred, and anything you might have done that may have caused the error. More information about this error may be available in the server error log. Additionally, a 500 Internal Server Error error was encountered while trying to use an ErrorDocument to handle the request. Also, it's forgotten it's static IP iSCSI services still launch (and work) Samba was working Logged in as root /usr/syno/etc/rc.d/S97apache-sys.sh restart No affect Tried rebooting For a laugh, I reissued certs cd /usr/syno/etc/ssl/ ./mkcert.sh Edited /etc/synoinfo.conf and set runHTTPS="no" /usr/syno/etc/rc.d/S97apache-sys.sh restart Now I'm look it at the same issue but without SSL Edited /usr/syno/apache/conf/httpd.conf-sys ErrorLog /var/log/httpd-error-sys.log #ErrorLog /dev/null Edited /etc/sysconfig/network-scripts/ifcfg-eth0 DEVICE=eth0 BOOTPROTO=dhcp ONBOOT=yes to DEVICE=eth0 BOOTPROTO=static ONBOOT=yes IPADDR=192.168.. NETMASK=255.255.255.0 Edited /etc/sysconfig/network-scripts/ifcfg-eth1 DEVICE=eth1 BOOTPROTO=dhcp ONBOOT=yes to DEVICE=eth1 BOOTPROTO=static ONBOOT=yes IPADDR=192.168.. NETMASK=255.255.255.0 /etc/rc.network restart So my device is back up, but management is still down. I've looked in the /var/log/httpd-error-sys.log file, but it's empty. Any advice? Link to comment Share on other sites More sharing options...
justgosh Posted August 28, 2014 Author Share #2 Posted August 28, 2014 (edited) Any suggestions on following would be appreciated. I still haven't figured out why it lost bits of the configuration. The files are all still present. Even though I've made the changes, it's not logging errors. Ultimately, I can't figured out hot to fix the 500 error. Edited August 31, 2014 by Guest Link to comment Share on other sites More sharing options...
justgosh Posted August 31, 2014 Author Share #3 Posted August 31, 2014 Bump Link to comment Share on other sites More sharing options...
