5.0 4493 update 4
anthonyuk
http://www.synology.com/en-global/relea ... l/DS3612xs
Fixed Issues
Upgraded OpenSSL to Version 1.0.1i to fix multiple security issues (CVE-2014-0224, CVE-2014-0221, CVE-2014-0195, CVE-2014-0198, CVE-2010-5298, and CVE-2014-3470).
Implemented fixes for Kerberos 5 to address multiple security issues that allow remote attackers to cause a denial of service (CVE-2012-1013, CVE-2014-4341, CVE-2014-4342, CVE-2014-4344).
Fixed an issue where files with ACL attributes could become inaccessible after being loaded in large batches when DiskStation acts as an NFS server.
Fixed an issue where the restore might not be successful when containing multiple subfolders in Time Backup.
Fixed an issue where DHCP server service does not map to the correct VLAN interface if the service started before VLAN is enabled.
Update 4 is out. Is it safe to install?
http://www.synology.com/en-global/releaseNote/model/DS3612xs
Fixed Issues
Yes it's safe check the update part of my guide in my signature for details.
Unusual update 4 outcome.
Logged into DSM and noticed update available. Without too much thought I started my sandbox DSM_VM and followed what I thought was correct process.
D/L update (directly from Syno) and wait...
Run script to setup flashupdt
proceed with update.
Initial Success, then notification msg says all volumes unloaded.
I see no volumes.Applied liberal use of profanity
Reboot.
All volumes back but packages missing, data missing and volumes go into build mode.
I dare say it was the Syno D/L that cooked me. Had i used bromolow file this would not have happened.
Anyone else with this?
DSM 5.0 4493 on VM Workstaion 10. 3 RAW mapped HDD.
Kudos, +1, love and devotion (take your pick) to fma965 for the installation / update guide. Brilliant work fella!
All appeared to go as per previous updates until the reboot when my N54L was invisible on the LAN afterwards and there was no login prompt displayed on the server (I'm running a "headed" config). I did the usual engineering stuff of swearing at it :twisted:, followed by a power cycle and all appears well now :grin:
