[SOLVED] Only 2 cores are recognised!
Re: [SOLVED] Only 2 cores are recognised!
Postby asgaroth » 15 Feb 2017 11:13
I'd be interested in this too, does DSM actually use all the cpu's and not just the hard coded 2 limit imposed. I'm currently running Jun's mod v1.01 with DSM 6.0.2 and 2 cpu's passed through via ESXi 6.5.
So far its running nicely, but I'd like to bump up the cpu count (only if it will use it).
On a side note, is there a restriction on the amount of memory DSM can use?
Cheers
Asgaroth
There are two major products of Berkeley, LSD and UNIX. We don't believe this to be strictly by coincidence.
Jeremy S. Anderson
User avatar
asgaroth
Postby Schnapps » 15 Feb 2017 14:00
This is a very long and old topic.
DSM is using all cores it has just that the System Information is showing in the CPU info tab the CPU as i3 and with 2 cores. That info is hardcoded in DSM for the XS3615+ model :)
CASE:Cooler Master Elite 120 Advanced MB:ASRock Q1900-ITX CPU:Intel J1900 RAM:GeIL 16GB PSU:Seasonic S12II-430 HDD:2xWD30EFRX & 2xST3000DM001 OS:Hyper-V Full Load:33dBi@38W
User avatar
Schnapps
Postby lastkiss » 15 Feb 2017 14:00
This problem has been haunting me
Really want to be able to display correctly
cpu:J4205
Thank you for everyone
1.DS214Play WD Red 4T×2
2.J4205-ITX 8G RAM Seagate 8T×2 LOADER: Jun's v1.01 loader DSM: DSM 6.0.2-8451
User avatar
lastkiss
Postby Schnapps » 15 Feb 2017 14:03
lastkiss wrote:This problem has been haunting me
cpu:J4205
3rd world problems :))
Dude, you have a problem if that tiny thing is bugging you.
User avatar
Schnapps
Postby Polanskiman » 16 Feb 2017 04:59
cpu:J4205
It just wont be possible unless you recompile DSM from scratch and change accordingly the source code to match your CPU name and speed.
Forum Moderator
MB: Gigabyte H97N-WIFI (rev. 1.0) CPU: Intel G3220 PSU: Seasonic Platinum-860 HDD: WD RED 2 x 2TB RAM: 16GB
BOOT USB: SanDisk Ultra Fit 16GB LOADER: Jun's v1.01 loader DSM: DSM 6.0.2-8451 Update 9 HOWTO: Tutorial DSM 6.0
User avatar
Polanskiman
Postby lastkiss » 16 Feb 2017 14:44
cpu:J4205
Thank you for your answer
User avatar
lastkiss
Postby opty » 17 Feb 2017 00:36
@ lastkiss
what about the turbo boost on J4205, is it working? what is your over all experience with this board. currently i am using Q1900 and very happy with it and in the market for a second NAS.
MB: ASRock Q1900-ITX| RAM: Kingston 8GB | HDD: 2xWD Red 3TB (SHR-1) | Jun's Baremetal 1.0.1 + DSM 6.0.2-8451 Update 9
opty
Postby lastkiss » 17 Feb 2017 13:26
opty wrote:@ lastkiss
how to test turbo boost?
I am also a beginner
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 92
model name : Intel(R) Pentium(R) CPU J4205 @ 1.50GHz
stepping : 9
microcode : 0x1e
cpu MHz : 1501.000
cache size : 1024 KB
physical id : 0
siblings : 4
core id : 0
cpu cores : 4
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 21
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave rdrand lahf_lm 3dnowprefetch ida arat xsaveopt pln pts dtherm tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust smep erms rdseed smap
bogomips : 2995.43
clflush size : 64
cache_alignment : 64
address sizes : 39 bits physical, 48 bits virtual
power management:
User avatar
lastkiss
Postby opty » 17 Feb 2017 14:05
> grep "MHz" /proc/cpuinfo
opty
Postby lastkiss » 21 Feb 2017 07:56
cpu MHz : 1501.000
cpu MHz : 1501.000
cpu MHz : 1501.000
cpu MHz : 1501.000
User avatar
lastkiss
PreviousNext
x
