tomcarmen Posted July 2, 2014 Share #1 Posted July 2, 2014 Hello everyone. I would like to make me a computer with xpenology I am very fascinated by the asrock q1900-itx. bay trail 10w with 4 sata. I read in the forum that some users have problems with USB ports. I want to know that the problems have been solved with the nanoboot 5.0.3.1 and with the bios update 06/03/2014 1:20 1. Improve USB compatibility. 2. Update CPU code. those of you who have this motherboard that can tell me if the motherboard and now '100% compatible with xpe? and if the usb3port are recognized. also the performance of the bay trail are better than n54l? sorry for these questions, but I am very careful to consumption and this motherboard is 'really interesting thanks for the answers Link to comment Share on other sites More sharing options...
fufik65 Posted July 5, 2014 Share #2 Posted July 5, 2014 Hello tomcarmen, I bought GIGABYTE J1800N-D2H, but I could not get USB ports Xpenology, I tried various settings and BIOS version. I went back to the seller and bought Asrock Q1900-itx.Motherboard is fully functional, USB2, USB3, WOL.I test Nanoboot x86 (DS214 +) and x64 (DS3612xs), all working.Excelent board not only for Xpenology. Link to comment Share on other sites More sharing options...
tomcarmen Posted July 5, 2014 Author Share #3 Posted July 5, 2014 thank you very much fufik65. I'll go buy it. how is the performance? Link to comment Share on other sites More sharing options...
fufik65 Posted July 5, 2014 Share #4 Posted July 5, 2014 fullHD,subtitles,DTS-HD sound Link to comment Share on other sites More sharing options...
Schnapps Posted July 5, 2014 Share #5 Posted July 5, 2014 So you're saying xpenology works fine on it? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
fufik65 Posted July 5, 2014 Share #6 Posted July 5, 2014 Link to comment Share on other sites More sharing options...
tomcarmen Posted July 5, 2014 Author Share #7 Posted July 5, 2014 thanks a lot Link to comment Share on other sites More sharing options...
lietz71 Posted July 6, 2014 Share #8 Posted July 6, 2014 (edited) Hi, I bought a MSI J1800I, but I got problems when uploading files (looks like stuttering) See here (first pic is upload, second is download) http://xpenology.com/forum/viewtopic.php?f=6&t=3375#p20032 How does the Asrock Q1900 performs when uploading a big file (>4GB)? Thanks. p.s. using NanoBoot-5.0.3.1 and DSM_DS3612xs_4493.pat I try also different cables/ switches and an additional nic (HP NC110T) Edited July 6, 2014 by Guest Link to comment Share on other sites More sharing options...
Schnapps Posted July 6, 2014 Share #9 Posted July 6, 2014 Q1900-ITX: http://i.imgur.com/YnhTeXO.png but with this: http://i.imgur.com/3p7WmO2.png on an UPS Link to comment Share on other sites More sharing options...
Billy6 Posted July 7, 2014 Share #10 Posted July 7, 2014 Q1900DC-ITX has (2x sata 300) and (2x sata 600). Can those 2 different connections been used for 1 raid 5 with 4 drives? Love this board! Thanks in advance Link to comment Share on other sites More sharing options...
Schnapps Posted July 7, 2014 Share #11 Posted July 7, 2014 Yup, that's how I have it. 4HDDs in SHR-1 on a Q1900-ITX that has 2x SATA2 and 2x SATA3 But also planning to insert a mSATA half size SSD directly in the board (yes there is a slot for mSATA half size SSD) for a hypervisor and to use DSM in a VM. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Billy6 Posted July 7, 2014 Share #12 Posted July 7, 2014 I'm sorry but I want to make a raid 5 configuration with this board. I saw in specs that it has 2 controllers with each 2 connections. I want to make one raid 5 with those 2 controllers. Or does someone know a cheap raid card that is supported by xpenology? Link to comment Share on other sites More sharing options...
Schnapps Posted July 7, 2014 Share #13 Posted July 7, 2014 Dude, I said it's working! Use DSM to create a SHR-1(RAID5) volume Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
tomcarmen Posted July 8, 2014 Author Share #14 Posted July 8, 2014 ordered Link to comment Share on other sites More sharing options...
Schnapps Posted July 8, 2014 Share #15 Posted July 8, 2014 Keep us updated and use the latest version 5.0 4493 Update 2 and the latest nanoboot Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
xpenologycacapee Posted July 8, 2014 Share #16 Posted July 8, 2014 I've got the same board on order. Looks like ESXI doesn't work now. How are you going to use virtualization on this board? Thanks Link to comment Share on other sites More sharing options...
Schnapps Posted July 8, 2014 Share #17 Posted July 8, 2014 I've got the same board on order. Looks like ESXI doesn't work now. How are you going to use virtualization on this board? Thanks I'm a beta user at VMware for vSphere and currently there are in beta with vSphere 6.0. I asked them on their forums how can i do it and got 2 replies with some boot parameters: My backup is not yet finished so i don't want to start before it reaches 100%. Try the following if you are quickier: https://communities.vmware.com/message/2399321#2399321 Link to comment Share on other sites More sharing options...
Schnapps Posted July 8, 2014 Share #18 Posted July 8, 2014 Just updated this evening to NanoBoot-5.0.3.1 (x64) and DSM 5.0-4493 Update 2. Still, USB devices are not recognized fufik65, you did someting else to your config? Thanks Link to comment Share on other sites More sharing options...
tomcarmen Posted July 9, 2014 Author Share #19 Posted July 9, 2014 have updated the bios to the latest version? http://www.asrock.com/mb/Intel/Q1900-ITX/index.it.asp?cat=Download&os=BIOS Link to comment Share on other sites More sharing options...
Schnapps Posted July 9, 2014 Share #20 Posted July 9, 2014 hmm, i have the latest BIOS i could download and install from their own bios If it's needed, i will update manually to the latest update 1.20 not sure what version i have now. i'm at work and the nas is, well... at home thanks for pointing this to me. Link to comment Share on other sites More sharing options...
tomcarmen Posted July 9, 2014 Author Share #21 Posted July 9, 2014 you're welcome. then you need to ask fufik65 if there are particular configurations in the bios. tomorrow I'll get the mother board let me know if you solve. also 'cause I read in the German forum of another user which has the same mb which runs all Link to comment Share on other sites More sharing options...
fufik65 Posted July 9, 2014 Share #22 Posted July 9, 2014 Hello tomcarmen, bios setting is very easy,latest version 1.20.ADVANCED-SUPER IO CONFIGURATION..disable serial ans paraller port.ADVNACED-USB COnFIGURATION...all enable.BOOT-CSM...enable and all set to LEGACY.Good luck Link to comment Share on other sites More sharing options...
tomcarmen Posted July 9, 2014 Author Share #23 Posted July 9, 2014 arrived, I'm starting to mount Link to comment Share on other sites More sharing options...
fufik65 Posted July 9, 2014 Share #24 Posted July 9, 2014 Let me know what is the result Link to comment Share on other sites More sharing options...
Schnapps Posted July 9, 2014 Share #25 Posted July 9, 2014 fingers crossed Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
