Ph1L Posted May 26, 2017 Share #1 Posted May 26, 2017 Hi all, I've posted several times, without any reply. I do really hope, that someone will answer this thread then. Issue: I've been following this thread, viewtopic.php?f=2&t=20216, and used OVF template from https://mega.nz/#!Agt00ZDT!lN5blyZc4gMa ... i9bF6ZBnY0 Then I power up the VM, and finds the DSM installation webinterface However, it keeps rebooting / reinstalling, after it says "we've found your old harddrives" I'm stuck here. Adding serial port (found in the thread linked to) didn't help. I really hope that someone can help me out, getting DSM 6+ alive. Thanks Quote Link to comment Share on other sites More sharing options...
chege Posted May 26, 2017 Share #2 Posted May 26, 2017 During loader startup did you switch to ESXI option? Its the last one in grub menu. Also you can try to build new VM from scratch, just use hard drive from OVF template. Quote Link to comment Share on other sites More sharing options...
Ph1L Posted June 6, 2017 Author Share #3 Posted June 6, 2017 Bump? Has anyone got DSM 6.1 installed, as brand new, on ESXi 6.5? Mine keeps rebooting, no matter what. Quote Link to comment Share on other sites More sharing options...
niedi74 Posted June 8, 2017 Share #4 Posted June 8, 2017 Yes, but I got only success with the Ds3615xs . Gesendet von meinem SM-G900F mit Tapatalk Quote Link to comment Share on other sites More sharing options...
filippo333 Posted June 8, 2017 Share #5 Posted June 8, 2017 During loader startup did you switch to ESXI option? Its the last one in grub menu. Also you can try to build new VM from scratch, just use hard drive from OVF template. From my experience testing, selecting the ESXI/VMware option causes the VM to not see any of the disks. Leaving it on the default works fine in VMware. 1 Quote Link to comment Share on other sites More sharing options...
rauan Posted January 23, 2018 Share #6 Posted January 23, 2018 On 6/8/2017 at 10:37 AM, niedi74 said: Yes, but I got only success with the Ds3615xs . Which version of DSM do you have on ESXi? 6.1.4-15217? Quote Link to comment Share on other sites More sharing options...
philber Posted April 17, 2018 Share #7 Posted April 17, 2018 Yes , fresh 3615XS 6.1.6 on ESXI 6.5.0 update 1 free. Didnt notice there was a vmware feature in the grub. So it is running without it and seems ok so far. I had issues with the 3617 (not appearing on ethernet). Phil Quote Link to comment Share on other sites More sharing options...
FranzK Posted May 23, 2018 Share #8 Posted May 23, 2018 On 4/17/2018 at 3:49 PM, philber said: Yes , fresh 3615XS 6.1.6 on ESXI 6.5.0 update 1 free. Didnt notice there was a vmware feature in the grub. So it is running without it and seems ok so far. I had issues with the 3617 (not appearing on ethernet). Phil What Images did you exactly use? If i this Template On 5/26/2017 at 2:38 PM, Ph1L said: OVF template from https://mega.nz/#!Agt00ZDT!lN5blyZc4gMa ... i9bF6ZBnY0 I don't see any Network Activity Host: 6.5.0 Update 1 (Build 6765664) Quote Link to comment Share on other sites More sharing options...
