mgrobins Posted May 24, 2017 Share #1 Posted May 24, 2017 Hi, I have been running a batch command on my PC to power off my NAS after some actions on the PC are complete. Upgrading to DSM 6 has broken this as I can no longer use root access through plink.exe. The commands I have been using are: C:\SSH_stuff\plink 192.168.1.2 -l admin -pw XXXXXX poweroff or echo n | C:\SSH_stuff\plink.exe -P 22 -ssh -pw XXXXX admin@192.168.1.2 "shutdown -h now" Both come back as "root access denied". Synology knowledge base advices for SSH to use "Sudo -I" to gain root access however I am not certain how to structure my plink.exe commands to achieve this as well as run the power off command. I tried the following and some derivatives with the -t which cleared up the ttl errors associated with sudo but could not get it to accept a password. echo n | C:\SSH_stuff\plink.exe -P 22 -t -ssh -pw XXXXX admin@192.168.1.2 "sudo -I" "poweroff" Hopefully someone can assist . Another potential method would be to have a script on my NAS I can run that enables root access or runs the poweroff command? If so ... advice on that would be helpful too - I'm pretty much a non Linux user after so many years absence from it I thnk this will be useful for anyone who needs root access and wants to run commands. Link to comment Share on other sites More sharing options...
