bpsystems Posted April 26, 2017 Share #1 Posted April 26, 2017 I am attempting to install DSM 6.1 using the v1.02a2 Jun loader on my system. I have a Supermicro X11SBA-LNF4 motherboard and Supermicro AOC-SAS2LP-MV8 hba with 8x4TB Seagate NAS drives. The loader seems to work but as soon as I get to Synology Web Assistant page I get a no hard disk found message. My hba adapter is detected in bios and all drives are visible but not found when it comes time to install. Is the SAS2LP-MV8 supported? If so, does anyone have any suggestions on how to get the drives to be detected? A search of compatible hardware did reference a Marvell 88SE94XX which suggests to me it is supported or was at one point. Thanks in advance Quote Link to comment Share on other sites More sharing options...
IG-88 Posted April 26, 2017 Share #2 Posted April 26, 2017 looks like you would need a extra kernel module mv_94xx.ko (your card has Marvell 9480) not provided by synology or jun's loader only way will be to build it yourself, i wrote a how to so you might try it? viewtopic.php?f=2&t=32744 as i already have enviroment for 3615xs dsm 6.1 i could provide the module or even bootimage for that version as you are using 1.0.2a2 you will have used 3617xs 6.1 you would have to change to 1.02a and 3615xs to use the bootimage i can provide atm (or someone else might provide the module/bootimage for 3617xs?) Quote Link to comment Share on other sites More sharing options...
bpsystems Posted April 26, 2017 Author Share #3 Posted April 26, 2017 If you are willing to provide either the boot image or module for the 3615xs I would be happy to try that. I was just trying out the latest to see if it worked. I will read over the how to and attempt to compile a module for the 3617xs for future use. Many thanks Quote Link to comment Share on other sites More sharing options...
IG-88 Posted April 26, 2017 Share #4 Posted April 26, 2017 (edited) i've tryed to build the module for 3617xs, dsm 6.1 as comiled there was only a mvsas.ko, but from the makefile it looks like it should contain the code for 94xx in my 3617xs vm the image booted and the mvsas driver was loaded, it's as good as i can do it atm, try it with your 3617xs installation and let us know what the result is 1.02a2 with mvsas http://s000.tinyupload.com/?file_id=047 ... 8171187484 Edited April 26, 2017 by Guest Quote Link to comment Share on other sites More sharing options...
bpsystems Posted April 26, 2017 Author Share #5 Posted April 26, 2017 IG-88 thank you! I installed the image and early tests look as though everything is functioning properly. I will update once I put the system through its paces. Quote Link to comment Share on other sites More sharing options...
TundraLu Posted August 4, 2018 Share #6 Posted August 4, 2018 On 4/26/2017 at 5:56 PM, bpsystems said: IG-88 thank you! I installed the image and early tests look as though everything is functioning properly. I will update once I put the system through its paces. Can you please share the file. I have the same card and am trying to get this to work as well. Quote Link to comment Share on other sites More sharing options...
TundraLu Posted August 11, 2018 Share #7 Posted August 11, 2018 On 4/26/2017 at 5:20 PM, IG-88 said: i've tryed to build the module for 3617xs, dsm 6.1 as comiled there was only a mvsas.ko, but from the makefile it looks like it should contain the code for 94xx in my 3617xs vm the image booted and the mvsas driver was loaded, it's as good as i can do it atm, try it with your 3617xs installation and let us know what the result is 1.02a2 with mvsas http://s000.tinyupload.com/?file_id=047 ... 8171187484 I need this file. Tried updating from DSM 5.2 to Juns 6.1 and i have a Marvell SAS 88SE controller and updated and cannot see the drives on the SAS controller. Please help me out sir. Quote Link to comment Share on other sites More sharing options...
bpsystems Posted August 11, 2018 Author Share #8 Posted August 11, 2018 (edited) Sorry I don't use the Marvell based controller anymore. I will check to see if I have a copy still but I got a new system about 6 months ago. Edited August 11, 2018 by bpsystems Typos Quote Link to comment Share on other sites More sharing options...
TundraLu Posted August 11, 2018 Share #9 Posted August 11, 2018 Just now, bpsystems said: Sorry I don't use the Marvell based controller anymore. I will check to see if I have a copy still but I have got a new system about 6 months ago now. What do you use now? Maybe i should buy a new controller. I already own 2 Supermicro SAS controller based on Marvel and figured use them. Thanks Quote Link to comment Share on other sites More sharing options...
Dfds Posted August 11, 2018 Share #10 Posted August 11, 2018 @TundraLu Post a request for the driver in the driver requests thread. Quote Link to comment Share on other sites More sharing options...
