bob_razowski Posted April 25, 2017 Share #1 Posted April 25, 2017 Hi, I installed properly the DSM6.0.2 with the 1.01 Jun loader. Everything works fine except... Hard drives never sleep. I guess the loader miss some drivers ? (I made the right settings in the control panel). My server is a Proliant MicroServer Gen8 Is the 1.0.2 loader fixing this (with the 6.1 upgrade) ? Thanks for your heeeelp Quote Link to comment Share on other sites More sharing options...
Gronaldo Posted May 8, 2017 Share #2 Posted May 8, 2017 Depending on applications installed, disk hybernation may not work as expected. Plex is causing disk spin up very frequently. Better not to use it, if disk spin up every 15-20 minutes, you recuce life span of the drives. Quote Link to comment Share on other sites More sharing options...
coalfield Posted May 12, 2018 Share #3 Posted May 12, 2018 Keen to understand this since its not they are spinning up all the time they simply never sleep! Quote Link to comment Share on other sites More sharing options...
