chilok Posted April 19, 2017 Share #1 Posted April 19, 2017 as i'm trying the ovf from viewtopic.php?f=2&t=26952&start=50 after it's up i installed photo station and checked Video conversion for mobile devices from indexing service however.. almost whatever video( video from my camera sony rx100III or any video i download ) i put it in the photo the system log will show as below System failed to convert video [/volume1/photo/00000.MTS] to mpeg4. is this a problem of the ovf or ... it's DSM problem ..? do you guys encounter the same issue ? Quote Link to comment Share on other sites More sharing options...
NeoID Posted April 25, 2017 Share #2 Posted April 25, 2017 I suppose it's a DSM 6.x issue. I have the same issue on 6.0, but not on 5.2. I have changed my serial and mac to match, but I see that messages.log for some reason still complains about it: 2017-04-24T13:13:25+02:00 moto synoflvconv: synoflvconv.cpp:584 Failed to convert video [/volume1/photo/foo/HDV_0005.MP4] to h.264 mp4. 2017-04-24T13:13:25+02:00 moto synocodectool: G1Licence.cpp:79 Licence not Success,error msg "SN format is wrong." 2017-04-24T13:13:25+02:00 moto synocodectool: SYNOCodecPatentG1.cpp:182 ValidateG1Licence failed 2017-04-24T13:13:27+02:00 moto synocodectool: G1Licence.cpp:79 Licence not Success,error msg "SN format is wrong." 2017-04-24T13:13:27+02:00 moto synocodectool: SYNOCodecPatentG1.cpp:235 ValidateG1Licence failed Edit: According to another thread here, the serial generator has been updated to work with the new format. Maybe changing the serial will help. I'm not sure whether a re-install is necessary or not. Will try when I get home. Link: https://xpenology.github.io/serial_gene ... r_new.html Quote Link to comment Share on other sites More sharing options...
chilok Posted April 26, 2017 Author Share #3 Posted April 26, 2017 Thanks neo, but i found that from this image https://mega.nz/#!xQ8XARbD!j_9UAmofUkLN ... ZHexMXrZS0 it's working on 6.0... but not upgradeable to 6.1.. by the way... i'm a complete newbie on xpenlogy... may i know here to find the log below ? Quote Link to comment Share on other sites More sharing options...
NeoID Posted April 26, 2017 Share #4 Posted April 26, 2017 I would advice against using DSM 6.1 just yet as it has a few critical issues according to other posts here. Even DSM 6.0 isn't as stable as DSM 5.2 in my opinion. I would also not recommend to just use any image/export you find online, but stick to Jun's. Regarding the logs: Make sure SSH is enabled. Use Putty to login as admin and use "sudo su" in order to elevate to root. Now you can write "tail /var/log/messages" in order to see the last messages. You can also read them in VI by using "vi /var/log/messages" and quit by using ":q!". 1 Quote Link to comment Share on other sites More sharing options...
