DS Cam 1 FPS?
  • 1 month later...
Set up a separate steam, one with lower resolution.
If your recording 1080 high bit rate etc and trying to convert and stream it's a lot of the software/hardware to handle.
I setup a separate stream, stream2 in the camera options which is for streaming purposes, much lower res.
It helped with the frame rate issue i had also at the start.
Play around with settings and see how you get on.
Mutlicam streaming is still only at 1fps tho, 4 cams on one screen etc, i cannot get it to stream any better.
Limitations of the software i read before.
