Virtual DSM Manager - Impossible to enable
worms
Hi guys,
I have a working Microserver G8 with DSM 6.0.2 u9
Last day I have try to activate and setup Virtual DSM Manager but I can't arrive at the end of first setup.
It ask to me to manage network connection and create a cluster (I have 2 ethernet connection with both static ip).
When I say "yes" he said that "can't create..." (I don't remember the message).
Anyone are using this system to virtualize anythings?
Thanks in advance.
Thanks a lot for helping me, sorry for my bad english.
I'll try with image :grin:
Network config
Step1
Step2 - Volume selection
Step3 - LAN selection
Step3.1 - First warning
Step3.2 - The ERROR
If I select the second NIC I'll get the same error.
Both NIC are connected to the same router, with 2 different IP (like u can see)
What can be?
I need to have 2 working Synology?
2017-03-20T10:51:48+02:00 ITData synoscgi_SYNO.Virtualization.Cluster_1_check_status[28880]: ccc/service.cpp:892 Failed to write /tmp/ccc/cache.etcd.state.json
2017-03-20T10:51:55+02:00 ITData synoscgi_SYNO.Virtualization.Cluster_1_create_SYNO.CCC.Cluster_1_create[29036]: ccc/host.cpp:1492 Start to create cluster
2017-03-20T10:51:55+02:00 ITData synoscgi_SYNO.Virtualization.Cluster_1_create_SYNO.CCC.Cluster_1_create[29036]: ccc/host.cpp:1295 Start check before host init
2017-03-20T10:51:55+02:00 ITData synoscgi_SYNO.Virtualization.Cluster_1_create_SYNO.CCC.Cluster_1_create[29036]: extent_pool_rodsp_key_get.c:16 open(/config/rodsys/local_key, O_RDONLY) failed, err=No such file or directory
2017-03-20T10:51:55+02:00 ITData synoscgi_SYNO.Virtualization.Cluster_1_create_SYNO.CCC.Cluster_1_create[29036]: ccc/host.cpp:127 GetLocalStorageKey(): SYNOExtentPoolRODKeyGet(0x7ffe682441e0, 13) failed, err=Failed to open file
2017-03-20T10:51:55+02:00 ITData synoscgi_SYNO.Virtualization.Cluster_1_create_SYNO.CCC.Cluster_1_create[29036]: ccc/host.cpp:1313 Failed to get storage key
2017-03-20T10:51:55+02:00 ITData synoscgi_SYNO.Virtualization.Cluster_1_create_SYNO.CCC.Cluster_1_create[29036]: ccc/host.cpp:1638 Rollback create cluster
2017-03-20T10:51:55+02:00 ITData synoscgi_SYNO.Virtualization.Cluster_1_create_SYNO.CCC.Cluster_1_create[29036]: ccc/service.cpp:246 service pkg-synohostcmdd ...[1]
2017-03-20T10:51:56+02:00 ITData synoscgi_SYNO.Virtualization.Cluster_1_create_SYNO.CCC.Cluster_1_create[29036]: ccc/service.cpp:246 service pkg-synohostcommd ...[1]
2017-03-20T10:51:56+02:00 ITData synoscgi_SYNO.Virtualization.Cluster_1_create_SYNO.CCC.Cluster_1_create[29036]: ccc/service.cpp:246 service pkg-synocccd ...[1]
2017-03-20T10:51:56+02:00 ITData synoscgi_SYNO.Virtualization.Cluster_1_create_SYNO.CCC.Cluster_1_create[29036]: ccc/service.cpp:246 service pkg-libvirtd ...[1]
2017-03-20T10:51:56+02:00 ITData synoscgi_SYNO.Virtualization.Cluster_1_create_SYNO.CCC.Cluster_1_create[29036]: ccc/service.cpp:246 service pkg-etcd_hyper ...[1]
2017-03-20T10:51:56+02:00 ITData synoscgi_SYNO.Virtualization.Cluster_1_create_SYNO.CCC.Cluster_1_create[29036]: ccc/service.cpp:246 service pkg-etcd ...[1]
2017-03-20T10:51:56+02:00 ITData synoscgi_SYNO.Virtualization.Cluster_1_create_SYNO.CCC.Cluster_1_create[29036]: core/utils.cpp:390 Failed to get register_ovs_by_ccc[0x0900 file_get_key_value.c:29]
2017-03-20T10:51:56+02:00 ITData synoscgi_SYNO.Virtualization.Cluster_1_create_SYNO.CCC.Cluster_1_create[29036]: core/utils.cpp:390 Failed to get register_ovs_by_ccc[0x2000 file_get_key_value.c:81]
2017-03-20T10:51:56+02:00 ITData synoscgi_SYNO.Virtualization.Cluster_1_create_SYNO.CCC.Cluster_1_create[29036]: ccc/host.cpp:1391 OVS is not enabled by virtualization, skip unregister
2017-03-20T10:51:56+02:00 ITData synoscgi_SYNO.Virtualization.Cluster_1_create_SYNO.CCC.Cluster_1_create[29036]: Cluster/cluster.cpp:231 Failed to create cluster, [401]
2017-03-20T10:51:56+02:00 ITData synoscgi_SYNO.Virtualization.Cluster_1_create[29036]: Cluster/Cluster.cpp:56 Bad response [{"error":{"code":401},"httpd_restart":false,"success":false}]/ request [{"addr":"172.16.16.1","api":"SYNO.CCC.Cluster","method":"create","version":1,"volume_paths":["/volume5"]}]
2017-03-20T10:54:56+02:00 ITData kernel: [ 294.790449] hpilo 0000:01:00.2: Closing, but controller still active
ovs_eth0 Link encap:Ethernet HWaddr 00:11:32:D8:09:76
inet addr:192.168.1.240 Bcast:192.168.1.255 Mask:255.255.255.0
ovs_eth1 Link encap:Ethernet HWaddr 00:11:32:FF:AD:E8
inet addr:172.16.16.1 Bcast:172.16.16.255 Mask:255.255.255.0
I have the same error.
Same with Open vSwitch on or off.
Using XPEnology bootloader for DSM 6.0.2-8451.5.
