ttsume Posted March 15, 2017 Share #1 Posted March 15, 2017 There were following problems when using ISCSI 1) Connection of ISCSI of a target happens rather long time from 1 to 5 min. 2) When copying big files everything is normal, but if to copy on iscsi a disk files of the small volume (kb) that copying can reach for hours 3) Also when copying small files sometimes there is a lag then only disconnection from a target helps If who knows the solution of this problem I will be very grateful... The storage is brought together on the supermicro server with network optical interfaces therefore connection of iscsi happens on 10G to the interface Link to comment Share on other sites More sharing options...
