Trial of Nanoboot (4493) - 5.0.3.1
The lastest version is 5.0.1.4 which works fine with DSM 5.0-4458
http://nanoboot.tk/
1. boot faster than gnoboot
2. able to customize mac address
3. able to customize SN
4. able to customize synoboot of VID & PID
5. provided x64 & x86 versions
6. works fine with transcode of photo station and video station
7. tested Contex DTV-01 DMB-TH USB stick works fine in video station
Edit syslinux.cfg for customizing mac address, SN, VID&PID.
EDIT by Trantor:
I just uploaded latest nanoboot release to my download server. I will update it when sancome release new versions.
Latest version is 5.0.3.1. (2014-06-11)
Download mirror : http://xpenology.trantor.be/nanoboot/
Edited by Guest
Just test 5.0-4458 x64.
Like Sancome said in his changelog it's build with 5.0 sources (synogpl-4458-bromolow.tbz, gcc473_glibc217_x86_64_bromolow-GPL.tgz) and not 4.3 like gnoboot builds.
It's based on gnoboot works, all is packed in the zImage (kernel + rd).
Just reporting what I saw ^^
x86 build is a good hope for people with old hardware, it's based on a DS214play which have an atom x86 only cpu :smile:
Unfortunately, I can't get the x86 build to work, keep saying migratable after reboot.
My realtek card (r8169) doesn't works. Intel one did (e1000e)
tested quicky 32 bits version with old 2 * Gigabyte motherboards
AMD - AM2+ --> GA-M61PME-S2P - RTL8201
INTEL - 775 --> GA-G31M-ES2L - RTL8111 *** no NIC Realtek problem as with gnoboot ***
RTL8169S add-on card ( not detected )
Edited by Guest
AMD - AM2+ --> GA-M61PME-S2 - RTL8201
and no NIC Realtek problems as with gnoboot
Good :grin:
Maybe a quick how to will help others to install x86 version :wink:
for the installation that is exactly as for 64 bits version :
use win32diskimager for make an USB key with NanoBoot-x86-5.0.1.4-fat.img
boot and use the Nanoboot menu upgrade 4458 version
install and run Synology Assistant
find the box and install with Synology Assistant --->>> DSM_DS214play_4458.pat --<<<<<
http://usdl.synology.com/download/DSM/5 ... y_4458.pat
reboot
after update 1 and 2 :
files are :
http://usdl.synology.com/download/criti ... 14play.pat -< update 1
http://usdl.synology.com/download/criti ... 14play.pat -< update 2
program terrminal ( authorize Telnet , SSH )
console ssh ( putty ) as root and with your password ------>>> putty : http://www.putty.org/
load the update file in server / config panel / update / manual update
load only but just before execute use this script in putty console :
sed 's/flashupdateDeb/flashupdateDeb1/' /autoupd@te.info > /autoupd@te.info1
mv /autoupd@te.info1 /autoupd@te.info
at this time only : execute
update is ok after some minutes / reboot
Edited by Guest
I've created a circuit for Power LED, Status LED, Beep sound and Power Button. I found that the circuit is working properly on gnoboot. With using nanoboot, it is not working if no DSM installed. After DSM is up, it becomes work proper.
It seems some different with gnoboot.
Edited by Guest
Does anyone have list of drivers in Nanoboot?
I installed on my system with LSI 9211-8i card and drives were not detected.
they work fine on Gnoboot 10.5
Thank you
I'll definitely need HBA support to test this as well. Same card.
+1 for LSI 9211-8i support
Also whatever drivers needed to run in ESXI.
edit: downloads don't seem to be working. I get the following on download page:
RSS
Search
下载
请勿把文件转移至其他网盘提供下载,如需转载,请提供如下链接!
Don't transfer files to other network disk available for download, For reprint, please provide the following link!
http://www.colafile.com/u/sancome
and http://www.colafile.com/u/sancome doesn't load.
