Hibernation and Wake-on-Lan on Xpenology DSM 6.x + HP Gen8
Postby piotrekp » 10 Feb 2017 12:12
My server is running on baremetal jun's loader, DSM 6.0. I've flashed spoofed MAC addresses to the the adapter.
It can successfully turn HDDs and the server itself off, but I can't wake it up by any way (I've tried from browser, from shared folders and from from synology apps).
Is it possible to successfully set up Hibernation and Wake On Lan on HP Gen8?
piotrekp
Re: Hibernation and Wake-on-Lan on Xpenology DSM 6.x + HP Ge
Postby captainfred » 14 Feb 2017 22:00
Wake on Lan works on my Gen8 but I'm running 5.2 latest not 6. Have you got it enabled in bios and ilo although not sure I had to.
captainfred
Postby sandisxxx » 17 Feb 2017 08:17
Hello, I'd recommend to try to use WakeOnLan software within the LAN to try to wake it up.
Of course it has to be allowed in BIOS or iLO.
If you can not make it work, maybe you can use another LAN cable and wake the server up by iLO web interface.
sandisxxx
x
