Tutorial: Install/Migrate DSM 5.2 to 6.0 (Jun's loader)
Re: Tutorial: Install/Migrate DSM 5.2 to 6.0 (Jun's loader)
Postby paranco » 09 Feb 2017 18:52
Thank Polanskiman, and all other users
With your help I was able to update my Asrock motherboard C2250D4i to DSM 6.2 update 8
Thanks again...
paranco
Postby jack78 » 09 Feb 2017 21:08
jaithn wrote:Hello everybody,
thank a lot for the tutorial. It worked!
One question though, DSM Info shows as a Prozessor "INTEL Core i3-4130 with 2 Prozessors à 3.4 GHz". But I have installed an i5-7500 with 4 Processors à 3.4 GHz. Is this only a mistake in the info-screen or do I need to do something to adjust this?
Thanks,
Jaithn
This is normal.
Speed is real, but procesor model is wrong, on every Xpenology.
HP Microserver Gen8 - i3-3220T, 4GB RAM, 4x3TB WD RED - DSM 6.0.2-8451 Update 8
HP Microserver G7 N40L - for test (or for sale) - DSM 6.0.2-8451 Update 8
jack78
Postby H_U_L_K » 09 Feb 2017 21:42
After migration from 5.2 to DSM 6.0.2-8451 update 8, quantity of RAM shows 8 gb, but instaled only 4.
I think it's similar to the situation with the processor, and the performance is not affected.
I have intel atom 2*1,6 ghz cores.
H_U_L_K
Postby dotslash » 10 Feb 2017 20:18
Hello world. I have a DSM 5.2-5644 upd 5 on HP Micro Server Gen8 with 1610 Celeron upgraded to DSM 6.0.2 8451 upd5 by jun's loader.
Question:
Can upgrade to DSM 6.0.2 8451 upd9 by control panel?
thanks
ooooookkkkay
Polanskiman wrote:
To everyone:
I recommend not to update to update 9. Some people are experiencing issues. A hard reboot may fix the problem in some instances but this does not seem to fix the issue for everyone, so stay on update 8 until further notice. Tutorial has been updated accordingly.
dotslash
Postby jack78 » 10 Feb 2017 21:16
You can, but i don't recomend. Use update8 in manual update from 1 post.
jack78
Postby spyrule » 12 Feb 2017 23:53
Does anybody know of the drivers for the Mellanox ConnectX2 cards are included in this build ?
spyrule
Postby mervincm » 13 Feb 2017 01:34
I suspect there may be driver issues with the three types of 10G cards I own.
OEM of Intel SFP+
-shows up but will neither accept a static IP nor a DHCP address, instead defaulting to a 169.x.x.x
-Firmware up to date
-Intel 82599 chipset (not listed specifically but it is seen and part of intel bundle so I "hoped" it would work)
-work OK in XPenology 5.2
IBM OEM 42C1792
-Broadcomm NetXtreme 2 (bnx2x) (listed and should work)
-firmware bnx2x-e1-7.0.29.0,
maybe firmware is not in correct locations (in 5.x it was copy bnx2x-e1-7.0.29.0.fw into /lib/firmware/bnx2x)
-shows up accept a static IP, good Write performance (400-800 MB/sec) terrible Read Performance (1-2 MB/Sec)
-Broadcomm BCM57710
Mellanox ConnectX-2 1 Port SFP+
-firmware=unknown
-not listed, not expected to work.
-not seen on boot, stops boot progression in fact.
-works OK in Windows test
mervincm
Postby orzyl » 13 Feb 2017 15:12
To which version can I upgrade my HP N40L (now i have 5.1, but can upgrade to 5.2 5644.5), to have phpvirtualbox working ?
Is it safe to upgrade? I need phpvirtualbox and working ACL on encrypted folders.
Please - if anybody knows, don't leave this post not replied. ;)
orzyl
Postby fonix232 » 13 Feb 2017 20:13
Are there any news about update 9? It isn't really specified what issues it is causing, and I can't see much about related topics either.
BOARD MSI B250I PRO | CPU Intel Pentium G4560
RAM 8GB Crucial DDR4 | CASE Bitfenix Prodigy mITX
fonix232
Postby billat29 » 13 Feb 2017 21:40
fonix232 wrote:Are there any news about update 9? It isn't really specified what issues it is causing, and I can't see much about related topics either.
It's been running on my N54L (disclaimer: There's a HP NC360T card in it) for at least 10 days. So far without me noticing any problems.
Hardware: N54L; 6GB ECC RAM; HP NC360T NIC; 3x4TB HDD
XPEnology: jun 1.01 loader; DSM 6.0.2-8451 update11
billat29
PreviousNext
x
