shailesh1 Posted September 27, 2016 Share #1 Posted September 27, 2016 Hello, I have just installed Xpenology on my Dell Optiplex 755. The install was very quick and easy but I was wondering if someone could help me with a couple of issues? 1. I have four 6TB disks installed but can only see 2 disks initialized. Is there any way to initialise the other disks in the software? BIOS is showing that all 4 disks are installed. 2. I did try to create both a volume and then a disk group as the volume error was failed to apply the settings. When I tried the disk group, I got the same error but not sure why. 3. Would it be better to buy a dedicated RAID controller card or use the inbuilt software version? Thanks in advance. Shailesh Link to comment Share on other sites More sharing options...
ente_b Posted September 28, 2016 Share #2 Posted September 28, 2016 sorry, my english is not good ... What is your BIOS-Version on the DO755MT? The last version on my DO755MT is A22. I have five 4TB-HDDs in my System, 2 in side and 3 in a hotswap-backplane. The last drive is on the internal eSATA-Port connected. I had activated in the BIOS after the drive has been connected on the Port. Gesendet von meinem SM-G935F mit Tapatalk Link to comment Share on other sites More sharing options...
shailesh1 Posted September 28, 2016 Author Share #3 Posted September 28, 2016 My bios version is also A22. I have the 4 disks connected to the 4 SATA ports. Which hotswap back plane did you use? Maybe it's because I'm using 6TB disks? I also enabled the raid setting in the bios but I had to disconnect all the drives first. If I try to access any of the drive settings while these drives are plugged in, the bios freezes. Not sure why that is. Link to comment Share on other sites More sharing options...
ente_b Posted September 28, 2016 Share #4 Posted September 28, 2016 Im using Seagate ST4000VN000 and this is the used backplane: Enermax EMK5301 In the BIOS use the AHCI-Mode, not RAID, not compatible Mode Link to comment Share on other sites More sharing options...
ekwie Posted September 28, 2016 Share #5 Posted September 28, 2016 wich DSM Version are you trying to install? This problem just sounds like DSM 6. There is no official bootloader for DSM6, installing will work but you cant create volumes. Link to comment Share on other sites More sharing options...
shailesh1 Posted September 28, 2016 Author Share #6 Posted September 28, 2016 I'm using DSM version 5. I heard about the issues with 6 so decided against using it. OK, I'll change the bios settings to AHCI-Mode. I'm using WD60EFRX as my disks, hopefully they are not the problem with the system. I will take a look at the Enermax EMK5301. Thanks. Link to comment Share on other sites More sharing options...
shailesh1 Posted September 28, 2016 Author Share #7 Posted September 28, 2016 I have changed the bios to AHCI-Mode and am still having the same issue. The error is still saying failed to apply settings. One message I just noticed is a system event warning - Abnormality detected. All volumes have been unmounted. I think the next step is to test all the drives are working correctly. Link to comment Share on other sites More sharing options...
ente_b Posted September 28, 2016 Share #8 Posted September 28, 2016 install a Windows on a small SSD, read the SMART values with AIDA64 ... Link to comment Share on other sites More sharing options...
UNSC-117 Posted September 29, 2016 Share #9 Posted September 29, 2016 I have changed the bios to AHCI-Mode and am still having the same issue. The error is still saying failed to apply settings. One message I just noticed is a system event warning - Abnormality detected. All volumes have been unmounted. I think the next step is to test all the drives are working correctly. Check sata cables swap Working HD's connect them where the ones don't work see if the working show up. Upgrade Bios or downgrade. Try a sata card if you have one Reinstall maybe bad install. Hope this help good luck. Link to comment Share on other sites More sharing options...
shailesh1 Posted September 29, 2016 Author Share #10 Posted September 29, 2016 Thanks for the tips, I'll give them a go. Link to comment Share on other sites More sharing options...
shailesh1 Posted September 29, 2016 Author Share #11 Posted September 29, 2016 I've now tested all 4 disks using the Western Digital Data Lifeguard for windows (I used an external USB enclosure to test each disk, one at a time) and all 4 disks passed. I then changed the sata cables and swapped around the disks. The same 2 disks are shown are not initialized. The abnormality message is also there. Seems like 2 of the hard drives are not liked by Xpenology. Not sure what to do next. Link to comment Share on other sites More sharing options...
berwhale Posted September 30, 2016 Share #12 Posted September 30, 2016 Have you used the two missing disks in another system previously? If so, you may need to clean off any existing partitions before DSM will initialize the disks... http://knowledge.seagate.com/articles/e ... Q/005929en Link to comment Share on other sites More sharing options...
shailesh1 Posted October 3, 2016 Author Share #13 Posted October 3, 2016 I did try and clean the partitions using the link and I managed to get all 4 disks initialized, so thank you very much for your help. Unfortunately, I still couldn't get a raid 5 volume created no matter which option I tried. I even tried creating a simple volume, no raid, with just 2 disks but still get the same error - failed to apply settings. I used both the automatic options and manual options but couldn't create any volumes. Maybe I'm missing a step? Link to comment Share on other sites More sharing options...
shailesh1 Posted October 3, 2016 Author Share #14 Posted October 3, 2016 I think I may have finally fixed the issue. I tried the version 5.2-5967.1 and rebuilt the DSM from scratch, only after using the diskpart utility again to clean all 4 disks. After loading the new version, I created a disk group which worked straight away. I then managed to create a RAID 5 volume with 16.36TB, so I hope it is working now. Thanks to everyone for your help. Link to comment Share on other sites More sharing options...
berwhale Posted October 3, 2016 Share #15 Posted October 3, 2016 You're welcome Link to comment Share on other sites More sharing options...
