mccltd Posted September 24, 2016 Share #1 Posted September 24, 2016 Hi, Can anybody advise if i can remove the 4 drives from my HP N54l and install them into a new HP Gen micro server without loosing the data. As I need a little more power for Plex and was thinking of upgrading. Link to comment Share on other sites More sharing options...
fabbe Posted September 26, 2016 Share #2 Posted September 26, 2016 no problem , i did it you can use the same usb key boot (or sd card) Link to comment Share on other sites More sharing options...
Hennie-M Posted September 28, 2016 Share #3 Posted September 28, 2016 I also did this succesfully. And when I was ready I also upgraded the cpu to a Xeon. I don't remember which type. Be carefull to remember the drive numbers and put them back in the same order Link to comment Share on other sites More sharing options...
mccltd Posted September 29, 2016 Author Share #4 Posted September 29, 2016 Thanks. Did you notice a speed improvement? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
fabbe Posted September 29, 2016 Share #5 Posted September 29, 2016 yes , work perfectly with plex Link to comment Share on other sites More sharing options...
