Install DS3612xs DSM4.2 build 3211++ on Proxmox(KVM)
neox
just to confirm I was able to install XPEnology DS3612xs DSM 4.2 build 3211++ (repack v1.2) on my proxmox v3 server using KVM virtualisation.
I just followed the virtualbox howto and adapt where need.
1°) create a KVM machine with :
- IDE harddrive, size 33MB (set 0.032 in the proxmox menu)
- any SATA drive the size you want but more thant 4GB that would be used as data
2°)according to the disk format you setup in step1, convert the synoboot...img into vm-xxx-disk-1.qcow2 using this command line in the proxmox shell
on my machine this gives me (my VM id is 106):
qemu-img convert -f raw -O qcow2 synoboot-trantor-4.2-3211-v1.2.img vm-106-disk-1.qcow2
3°) boot this machine
4°) launch the synology assistant and install the pat file provided
5°) the first reboot failed as installer reformat the IDE0 drive,
simple workaround : just redo the step2 to recreate the IDE0 drive
6°) finally boot into your brand new DSM4.2 KVM.
Enjoy
20131122 : Edit : if data drive are 4GB the installer fails while formating system partition, I directly upgrade to 8GB and installer works fine
