oktisme Posted June 13, 2016 Share #1 Posted June 13, 2016 So I got DSM 6 (6.0.1-7393) working (volumes stay mounted). Here's a VMware VM if anyone wants to try it. You can use VMware Player to run it. Just add a new SATA hard drive before booting. If you want console access, use PuTTY to connect to the named pipe \\.\pipe\com_1 (speed 115200) to connect to the VM's serial port. This is pretty much it: add a SATA disk, boot and go to http://find.synology.com, configure and you're done. DSM 6.7z 1 1 Link to comment Share on other sites More sharing options...
brantje Posted June 13, 2016 Share #2 Posted June 13, 2016 So how did you cracked it? And will there be a iso for the new bootloader? Posted via Xpenology.us Link to comment Share on other sites More sharing options...
oktisme Posted June 13, 2016 Author Share #3 Posted June 13, 2016 So how did you cracked it? I found the protection code and patched it. I guess this isn't a new protection with v6 and that XPEnology did the same thing for v5, so I don't know why a v6 hasn't already been done. will there be a iso for the new bootloader? It's somewhat already possible to install that on a physical machine, but the only drivers included by Synology are the ones for their hardware. To make it usable somewhere else you'd first need to compile the drivers. Link to comment Share on other sites More sharing options...
carlozo Posted June 13, 2016 Share #4 Posted June 13, 2016 doesn t work for me Link to comment Share on other sites More sharing options...
FranzelM Posted June 13, 2016 Share #5 Posted June 13, 2016 Hello, it is the first time that I use VMware! And it is working fine! I use and old SATA-Drive ... I will test it a little. Franz Link to comment Share on other sites More sharing options...
mtbf99 Posted June 13, 2016 Share #6 Posted June 13, 2016 Nice work. Can you share your knowledge with xpenology dev team ? Thanks Link to comment Share on other sites More sharing options...
oktisme Posted June 13, 2016 Author Share #7 Posted June 13, 2016 I'm pretty sure they are plenty capable of doing what I did, but just don't want to for some reasons. Link to comment Share on other sites More sharing options...
carlozo Posted June 13, 2016 Share #8 Posted June 13, 2016 press tab to edit options automatic boot in 0 seconds... Loading ../zimage... ok Loading../rd.gz... ok early console in decompress_kernel Decompressing Linux... Parsing ELF... done. Bootng the kernel. _ this is what I get look like crash in 0 seconds Link to comment Share on other sites More sharing options...
imaleecher Posted June 13, 2016 Share #9 Posted June 13, 2016 press tab to edit optionsautomatic boot in 0 seconds... Loading ../zimage... ok Loading../rd.gz... ok early console in decompress_kernel Decompressing Linux... Parsing ELF... done. Bootng the kernel. _ this is what I get look like crash in 0 seconds Proceed forward to http://find.synology.com on another system and it should find a new NAS on your network. Had to mess around with the boot and select "Install" vs "Run" a few times to get it to finally accept DSM 6.0.1 install. I was able to get it to boot but could not create a volume. Will try again when I have more time. Thanks okitsme for your contribute. Link to comment Share on other sites More sharing options...
oktisme Posted June 13, 2016 Author Share #10 Posted June 13, 2016 You MUST NOT boot it with Install (that's why there's no time to choose). Let it boot, and go to find.synology.com. If you've booted it once with Install, you should restore the latest snapshot to make sure it didn't mess anything. And yeah, there's no console on screen with Synology's kernel. So after the "Booting the kernel" message, the screen doesn't change but it's running in the background. If you really want console access, read the initial post. Link to comment Share on other sites More sharing options...
spinline Posted June 14, 2016 Share #11 Posted June 14, 2016 nice work. Link to comment Share on other sites More sharing options...
lovelove Posted June 14, 2016 Share #12 Posted June 14, 2016 Hope there will be an easy installation pack soon Link to comment Share on other sites More sharing options...
oktisme Posted June 14, 2016 Author Share #13 Posted June 14, 2016 I don't plan on doing that ATM. Link to comment Share on other sites More sharing options...
gits68 Posted June 14, 2016 Share #14 Posted June 14, 2016 So how did you cracked it? I found the protection code and patched it. I guess this isn't a new protection with v6 and that XPEnology did the same thing for v5, so I don't know why a v6 hasn't already been done. Hi, could you explain what you patched ? and how ? thanks in advance. Regards. Link to comment Share on other sites More sharing options...
koroziv Posted June 14, 2016 Share #15 Posted June 14, 2016 Thanks I wish it was vm version 9; it is version 12 and can't use it on my esxi 6.0 Link to comment Share on other sites More sharing options...
substorm Posted June 14, 2016 Share #16 Posted June 14, 2016 Wow, good job Oktisme. This looks very promising. As Koroziv already mentioned, is there a way to make this work on esxi 6? Are packages and volumes fully accessible? Has anyone tested with this indexed content search and document previews? Link to comment Share on other sites More sharing options...
oktisme Posted June 14, 2016 Author Share #17 Posted June 14, 2016 Here, I downgraded it to 10.x since it tells me that 9 doesn't support SATA, which is required, and that 10 is supported by ESXi 6.0. DSM 6 Workstation 10.x.7z I haven't tested all packages, but so far they work. Volumes are accessible and stay mounted. I just tried the document viewer with pdf, xlsm, docx and it works. I can configure the indexed search and it tells me that the indexing is done; don't really know how to test if it really works though. Link to comment Share on other sites More sharing options...
dr_drache Posted June 14, 2016 Share #18 Posted June 14, 2016 how would I move my current xpenology NAS to this? Link to comment Share on other sites More sharing options...
abced Posted June 14, 2016 Share #19 Posted June 14, 2016 how would I move my current xpenology NAS to this? Don't you think it would be better to wait a little bit? I think this build is more for playing around, not for serious use. Link to comment Share on other sites More sharing options...
hokies Posted June 14, 2016 Share #20 Posted June 14, 2016 has anyone gotten this working with virtualbox? do i add all .vmdk to the vm? Link to comment Share on other sites More sharing options...
d1wepn Posted June 14, 2016 Share #21 Posted June 14, 2016 great job oktisme! do you happen to know how to recompile the kernel with additional drivers? Link to comment Share on other sites More sharing options...
TBK Posted June 14, 2016 Share #22 Posted June 14, 2016 If you like me would like to play around with the Virtual DSM Manager, then you need more than one NIC. In VMware add more NICs. Make sure the VM is off and then open the "DSM 6.vmx" file in a text editor. Find ethernetXX.virtualDev = "e1000" (eg. ethernet2.virtualDev = "e1000") and change it to ethernetXX.virtualDev = "e1000e" save the changes and then start the VM again. DSM will discover the new NICs. Link to comment Share on other sites More sharing options...
abced Posted June 15, 2016 Share #23 Posted June 15, 2016 Do encrypted shares work now? Link to comment Share on other sites More sharing options...
substorm Posted June 15, 2016 Share #24 Posted June 15, 2016 @Oktisme: glad to hear everything is working. Unfortunately, on my end I tried to add the last one you posted to my esxi inventory and it was complainig about unsupported disk. Even tried converting it but got i/o error in the vmware converter. Link to comment Share on other sites More sharing options...
koroziv Posted June 15, 2016 Share #25 Posted June 15, 2016 Here, I downgraded it to 10.x since it tells me that 9 doesn't support SATA, which is required, and that 10 is supported by ESXi 6.0. DSM 6 Workstation 10.x.7z I haven't tested all packages, but so far they work. Volumes are accessible and stay mounted. I just tried the document viewer with pdf, xlsm, docx and it works. I can configure the indexed search and it tells me that the indexing is done; don't really know how to test if it really works though. Thank you very much for this. I still can't boot on my setup, but that's my problem I run esxi on a hp gen8; I copied the vm, added a new hdd and no joy : "Failed to start the virtual machine. Module DevicePowerOn power on failed. Unable to create virtual SCSI device for scsi0:0, './Boot.vmdk.REDO_kF29hq' Failed to open disk scsi0:0: Unsupported or invalid disk type 2. Ensure that the disk has been imported." Link to comment Share on other sites More sharing options...
