Bios requirements for XPEnoboot?
jasdjensen
I'm wondering if there are specific settings needed in bios for XPEnoboot to load properly?
I've tried a couple of very different usb flash drives and have validated by md5 my img file. But each time I try to boot from the USB, I see the XPEnoboot logo and it seems to stop there. It never gets far enough to load the network, and I never see a login prompt. I've played with various PC Bios settings, but am wondering if there are specific bios features that are required to be enabled or disabled?
Is there a method of troubleshooting to find out where I'm stuck and how to fix it?
Thanks.
Jason
Hardware:
Motherboard ECS 945GCT-M
CPU Intel Core 2 Duo E6400 @ 2.13GHz
Network Intel PRO/1000 MT Desktop Adapter
Network#2 Realtek PCIe FE Family Controller
Memory 2x2GB Crucial DDR2 6400 CT25664AA800.M16FH
additional Supermicro SAT2-MV8 sata controller
It was my Supermicro SAT-MV8 card.. apparently it doesn't like it. I've thrown a different SATA card in there and it boots fine now. Thanks for the help!
I have the same card. Apparently Xpenoboot broke support for some Marvell cards. It use to work with Nanoboot 5.1. So basically, I can't use those cards either until it's fixed with a future version of the bootloader
