Drivers requests
Re: Drivers requests
Postby Trantor » 07 Feb 2016 14:36
sfu420 wrote:And what about the NVMe driver, can we see it in the new release?
It can be found in kernel configuration: Device Drivers -> Block devices -> NVM Express Block Device
Done. NVMe support added (nvme module loaded at boot)
@Seb@tien and @mavi : I don't have dvb adapter to test but next release (5644.5) should fix it
@jansjobe : I will look to add most common HighPoint adapters, but it will not be included in 5644.5 build.
@changlimchoe: Same as above
@4got20: Please read viewtopic.php?f=2&t=10973
@ALL : Next release will be available very soon :)
- iSCSI works (block and files)
- Time Backup fixed
- VirtualBox package works
- Add device mapper mirror (dm-mirror, dm-log and dm-region-hash modules)
- Add NVMe support
- Add evdev and button module to boot sequence
- Update mpt3sas, aacraid, e1000e (I219 support), bnx2, bnx2x, megaraid_sas drivers
Migration from 5592 to 5644 keeps iSCSI lun/target, data and volumes : OK
User avatar
Trantor
Postby Seb@tien » 07 Feb 2016 15:35
Thank you for ur job ;)
Seb@stien
Seb@tien
Postby Agent-Orange » 08 Feb 2016 16:16
Cool, cant wait to get my NAS finally working. I hope the updated megaraid drivers works :-)
Agent-Orange
Postby Jonb » 09 Feb 2016 06:32
A Simple Request: ASIX MCS7830 -- USB 2.0 to 10/100M Fast Ethernet Controller
http://www.asix.com.tw/products.php?op= ... 109;74;109
Thank you very much!
Best.
Jonb
Postby andyn33 » 09 Feb 2016 17:39
Is it possible to include this driver?
Intel(R) 82562V-2 10/100 Network Connection
In the compatibility list on the forum is not mentioned even if many other similar intel cards are supported.
Thank you for your time!
Best regards,
Andrea
andyn33
Postby Trantor » 11 Feb 2016 09:20
andyn33 wrote:Intel(R) 82562V-2 10/100 Network Connection
Supported by e1000 driver.
Hardware supported list updated ;)
User avatar
Trantor
Postby loderunner » 11 Feb 2016 13:30
please, help.. i have supertrack ex8530 it's checked as compatible, but cant'n insnall xpeno on sata drive attached to. how to load kernel driver? thank you!
loderunner
Postby acer21 » 12 Feb 2016 02:10
i need help on how i can able to use the highpoint rocketraid sas controller 2680SGL xpenoboot doesnt recognize any drive and prompts me to install drives before entering, although in boot up upon powering on of the desktop it detects all the drives
heres what i found on their website
www.highpoint-tech.com/USA_new/cs-serie ... wnload.htm
thank you
acer21
Postby sfu420 » 12 Feb 2016 18:58
- Add NVMe support
Great news! :)
I think, this update will solve all of my problems.
Thank you very much!!!
sfu420
Postby ecbrad » 13 Feb 2016 01:50
XPEnology installs and works but it only sees 6 of the 7 HDD's. I grabbed this info from the system with the Thecus DOM installed which can see all 7 HDD's
Thecus N7710
SATA1: Intel Corporation Device 1c02
SATA2: Silicon Image Inc. SiI 3132 Serial ATA Raid II Controller
USB2.0-1: Intel Corporation Device 1c2d
USB2.0-2: Intel Corporation Device 1c26
USB2.0-3: Renesas Technology Corp. Device 0015
USB3.0-1: Renesas Technology Corp. Device 0015
WAN/LAN1: Intel Corporation 82574L Gigabit Network Connection
LAN2: Intel Corporation 82574L Gigabit Network Connection
CPU: Intel CPU G850 @ 2.90GHz
Memory: 3936 MB
DOM: Single DOM
ecbrad
PreviousNext
x
