-> HARDWARE SUPPORTED LIST FOR DSM 5.2 <-
Trantor
This list is based on the drivers loaded in XPEnoboot 5.2-5967.1 (17/07/2016)
If something is missing request it HERE
EDIT 17/07/2016 : Add details according 5967.1 release (pata_amd, pata_jmicron, hpsa, cciss, ixgbe, r8101, r8169, r8168) + add more details for ata_piix
NETWORK
AMD
amd8111e : AMD 8111 (new PCI LANCE)
pcnet32 : AMD PCnet32 PCI
Asix
asix : ASIX AX88xxx Based USB 2.0 Ethernet Adapters
ax88179_178a : ASIX AX88179/178A USB 3.0/2.0 to Gigabit Ethernet
Atheros / Qualcomm
atl1 : Atheros/Attansic L1 Gigabit Ethernet
atl1c : Atheros L1C Gigabit Ethernet
atl1e : Atheros L1E Gigabit Ethernet
atl2 : Atheros L2 Fast Ethernet
alx : Qualcomm Atheros AR816x/AR817x
Broadcom
b44 : Broadcom 440x/47xx
bnx2 : Broadcom NetXtremeII BCM5706/BCM5708/5709/5716
bnx2x : Broadcom NetXtremeII 10Gb BCM57710/BCM57711/BCM57711E/BCM57712
tg3 : Broadcom Tigon3 BCM5705/BCM5703/BCM5702/BCM5701/BCM5700/BCM5721/BCM5751/BCM5788/BCM5704/BCM5752/BCM5789
tg3 : BCM5723/BCM5761/BCM5787/BCM5755/BCM5722/BCM5754/BCM57781/BCM57785/BCM5718BCM57765/BCM57761
tg3 : BCM5719/BCM5725/BCM5762/BCM5720/BCM57790/BCM57795/BCM57766/BCM57780
Brocade
bna : Brocade 1010/1020 10Gb Ethernet
Chelsio
cxgb : Chelsio 10Gb Ethernet
cxgb3 : Chelsio Communications T3 10Gb
cxgb4 : Chelsio Communications T4 Ethernet
Cisco
enic : Cisco VIC Ethernet NIC
HP
hp100 : HP 10/100VG PCLAN (ISA, EISA, PCI)
Intel
e100 : Intel PRO/100+
e1000 : Intel PRO/1000 CT/F/GT/MF/MT/T/XF/XT 82543GC/82546EB/82545EM/82540EM/82540EP/82544GC/82544EI/82547EI/82541EI
e1000 : 82545GM/82546GB/82541ER/82547GI/82541GI/82541PI/82566MM/82566MC/82566DM/82566DC/82563EB/82564EB/82562
e1000e : 82573L/82572EI/82571EB/82573E/82573V/82567/82574L/82566MM/82566MC
e1000e : 82566DM/82566DC/82563EB/82574IT/82583V/82579LM/82579V/82577LC/82577LM
e1000e : 82578DC/82578DM/Gigabit CT Desktop Adapter/PRO/1000 PT/PF/I217-LM/V/I218-V/LM/I219 LM/V
igb : 82576EB/82576NS/82580EB/82575EB/Gigabit ET/ET2/EF/VT
igb : I350-AM4/I350-BT2/I350-AM2/I350-T2/I350-T4/I350-F2/I350-F4
igb : I340-F4I340-T4/I210-AT/I210-IS/I210-IT/I210-T1/I210-AS/I210-CS
ixgbe : Intel 10 Gigabit AF DA/AT/AT2/CX4/XF LR/XR/82599EB/82598EB/82599ES/82599EN
ixgbe : X540-T1/X540-T2/540-AT2/X520-SR1/X520-SR2/X520-DA2/X520-LR1/X520-DA1/X520-DA4/X520-QDA1/X520-T2 X550-BT2/AT/AT2 X550-T1/T2
i40e : Intel 40 Gigabit X710-AM2/XL710-AM1/XL710-AM2/X710-DA2/X710-DA4/XL710-QDA1/XL710-QDA2
JMicron
jme : JMicron® PCI-Express Gigabit
Marvell
skge : Marvell Yukon Gigabit Ethernet
sky2 : Marvell Yukon 2 88E8021/88E8022/88E8035/88E8036/88E8038/88E8050/88E8052/88E8053/88E8055/88E8061/88E8062, SysKonnect SK-9E21D/SK-9S21
Microsoft Hyper-V
hv_netvsc : Microsoft Hyper-V virtual network driver
Mellanox
mlx4_en : Mellanox Technologies 10Gbit Ethernet
NVIDIA
forcedeth : nForce Ethernet
QLogic
qla3xxx : QLogic QLA3XXX Network Driver
qlcnic : QLOGIC QLCNIC 1/10Gb Converged Ethernet
qlge : QLogic QLGE 10Gb Ethernet
Realtek
r8101 : RTL8100E/RTL8101E/RTL8102E-GR/RTL8103E(L) RTL8102E(L)/RTL8101E/RTL8103T RTL8401/RTL8401P/RTL8105E RTL8402/RTL8106E/RTL8106EUS
r8168 : RTL8111B/RTL8168B/RTL8111/RTL8168 RTL8111C/RTL8111CP/RTL8111D(L) RTL8168C/RTL8111DP/RTL8111E
r8168 : RTL8168E/RTL8111F/RTL8411 RTL8111G/RTL8111GUS/RTL8411B(N) RTL8118AS
r8169 : RTL8110SC(L) RTL8110S/RTL8110SB(L)/RTL8169SB(L)/RTL8169S(L)/RTL8169
r8150 : USB RTL8150 based Ethernet device
r8152 : RTL8152/RTL8153 Based USB 2.0/3.0 Ethernet Adapters
SiS
sis900 : SiS 900/7016
sis190 : SiS190/SiS191
VIA
via-rhine : VIA Rhine
via-velocity : VIA Velocity
Virtio
virtio_net : Virtio network driver
VMware
vmxnet3 : VMware VMXNET3 ethernet driver
STORAGE
SATA
Intel
ata_piix : Intel ICH5/6/7/8/9/10 SATA support and Intel ESB/ICH/PIIX3/PIIX4 PATA support
Marvell
sata_mv : Marvell Serial ATA 88SX[56]0[48][01] PCI(-X), [67]042 PCI-X/PCIe and SOC devices.
NVIDIA
sata_nv : NVIDIA SATA support
Promise
sata_sx4 : Promise SATA SX4 support
sata_promise : Promise Serial ATA TX2/TX4
ServerWorks
sata_svw : ServerWorks Frodo / Broadcom/ Apple K2 SATA support
Silicon Image
sata_sil24 : Silicon Image 3124/3132 SATA support
sata_sil : Silicon Image SATA support
SiS
sata_sis : SiS SATA 964/965/966/180 and PATA 180 support
ULi
sata_uli : ULi Electronics SATA support
VIA
sata_via : VIA SATA support
Vitesse
sata_vsc : VITESSE VSC-7174 / INTEL 31244 SATA support
PATA
AMD/Nvidia
pata_amd : support for the AMD and NVidia PATA interfaces
JMicron
pata_jmicron : JMicron IDE controller support
SiS
pata_sis : SiS PATA support
VIA
pata_via : VIA PATA support
SCSI/SAS
3ware
3w-9xxx : 3ware 9xxx SATA-RAID support
3w-sas 3ware 97xx SAS/SATA-RAID support
Adaptec
aacraid : Adaptec AACRAID support (Dell PERC2, 2/Si, 3/Si, 3/Di, HP NetRAID-4M, IBM ServeRAID & ICP SCSI), HBA 1000 series
aic94xx : Adaptec AIC94xx SAS/SATA support
ARECA
arcmsr : ARECA (ARC11xx/12xx/13xx/16xx) SATA/SAS RAID Host Adapter
HighPoint
hptiop : HighPoint RocketRAID 3xxx/4xxx Controller support
HP
cciss : Smart Array 5300 5312 532 5i 6400 6400EM 641 642 6422 6i E200 E200i E500 P600 P400 P400i P700m P800
hpsa : Smart Array P212 P410 P410i P411 P812 P712m P711m ; (Gen6/7 Controllers)
hpsa : Smart Array P222 P420 P420i P421 P822 P220i P721 ; (Gen8 Controllers)
hpsa : Smart Array P430 P430i P431 P830 P830i P831 P731m P230i P530 P531 ; (Gen8.5 Controllers)
hpsa : Smart Array P440 P441 P840 P440ar P244br H240 H241 H240ar H244br ; (Gen9 Controllers)
hpsa : HP StorageWorks 1210m P1224 P1228 P1228m P1224e P1228e P1228em
IBM
ips : IBM ServeRAID support
LSI
megaraid_sas : MegaRAID SAS 9361-8i/9361-4i9341-8i/9341-4i/9380-8e/9380-4i4e/9270-8i9271-4i/9271-8i/9271-8iCC
megaraid_sas : 9286-8e/9286CV-8e/9286CV-8eCC/9265-8i/9285-8e/9240-4i/9240-8i/9260-4i/9260CV-4i/9260-8i/9260CV-8i
megaraid_sas : 9260DE-8i/9261-8i/9280-4i4e/9280-8e/9280DE-8e/9280-24i4e/9280-16i4e/9260-16i/9266-4i/9266-8i/9285CV-8e
mpt2sas : LSI SAS 6Gb/s Host Adapters SAS2004, SAS2008, SAS2108, SAS2116, SAS2208, SAS2308 and SSS6200
mpt3sas : LSI SAS 12Gb/s Host Adapters SAS3004, SAS3008, SAS3108
Marvell
mvsas : Marvell 88SE64XX/88SE94XX SAS/SATA support (SAS/SATA 3Gb/s PCI-E 88SE64XX and 6Gb/s PCI-E 88SE94XX)
