XPEnology DS3612xs DSM 4.2 build 3211++ (repack v1.2)
Postby Trantor » 06 Aug 2013 18:11
What's new ?
- AMD CPU support
- Add / update Network / SATA / SCSI / SAS / USB drivers
- Add PATA support
- USB OHCI support
- SSH access enabled by default
- DM-Mirror support for LVM2 physical relocation (include dm-log, dm-region-hash and dm-mirror modules. thanks totalnas)
- LSI MPT HBA support (mpt2sas.ko load at boot in ramdrive)
- VMware support (PVSCSI and Balloon drivers)
- Add experimental support for acpi / powermanagement (manually insmod modules on supported hardware)
- Include bootstrap ipkg setup script (see changelog for details)
To convert .img file to .vdi (virtualbox)
30-08-2013
Version 1.2 is now available : http://xpenology.trantor.be/4.2.php (please click on ad to help me with this project)
:arrow: For unsupported hardware please post your driver request here
Known Issues:
WARNING : If you upgrade from 4.2-3202 v1.0 backup your data before upgrade !!
As usual give feedbacks :)
See changelog for full list of fix and supported hardware:
Code: Select all
CHANGELOG
v1.2 (30/08/13)
- Fix boot hang issue with some marvell controllers (fixed sata_mv.c)
- Replace megaraid_sas driver with the latest one from LSI website
- Include bootstrap ipkg setup script (/root.profile is already modified) : after setup just log to ssh and type :
sh syno-i686-bootstrap_1.2-7_i686.xsh
reboot, log again to ssh and type
ipkg update
ipkg upgrade
v1.1 (24/08/13)
- Upgrade to 4.2-3211 build
- Build latest aacraid drivers (Adaptec RAID 71xx/72xx/78xx and IBM ServeRAID adapters)
- Enabled /proc/acpi/event (build ACPI_PROC_EVENT)
- Build the VMware Balloon driver as module
- Fix issue that USB devices was detected as esata (modifying usbportcfg and esataportcfg in synoinfo.conf, maybe need some adjustment depending on harware)
v1.0 (06/08/13)
- The .config file is included in kernel
- DM-Mirror support for LVM2 physical relocation (include dm-log, dm-region-hash and dm-mirror modules)
NETWORK
Replace the REALTEK r8169 driver with the r8168 v8.036 (RTL8111x/RTL8168x/RTL8411x)
REALTEK driver r8101 v1.024.00 (RTL8100x/RTL8101x/RTL8102x/RTL8103x/RTL8401x/RTL8105x/RTL8106x)
INTEL e1000e driver to v2.4.14 (support I217x and I218x chip)
3COM 3c590/3c900 series (592/595/597), 3cr990
AMD PCnet32
Atheros L2, L1
Atheros L1C (ATL1E)
Atheros L1E (ATL1E)
AMD 8111 (AMD8111_ETH)
D-LINK DL2000/TC902x-based Gigabit Ethernet (DL2K)
Broadcom 440x/47xx, NetExtremeII, CNIC, Tigon3 (HP NCxx)
Intel PRO/100+, PRO/1000, 82575/82576, 82586/82593/82596
JMicron JMC250 (jme)
Marvell Yukon
Marvell Yukon 2 (sky2) : 88E8021/88E8022/88E8035/88E8036/88E8038/88E8050/88E8052/88E8053/88E8055/88E8061/88E8062, SysKonnect SK-9E21D/SK-9S21
Nvidia nForce
QLogic QLA3XXX, QLCNIC
Realtek 8139,8129,8130,8169
SiS SiS900/7016, SiS190/SiS191
VIA Rhine (via-rhine) : (Rhine-I (VT86C100A), Rhine-II (VT6102), or Rhine-III (VT6105)
VMware vmxnet3
USB
USB_OHCI_HCD (thanks totalnas for the tip)
SATA
Intel ESB, ICH, PIIX3, PIIX4
Marvell
NVidia
Silicon Image 3124/3132
SiS 964/965/966/180
VIA SATA support (SATA_VIA)
SCSI
3ware 5/6/7/8xxx ATA-RAID
3ware 9xxx SATA-RAID
3ware 97xx SAS/SATA-RAID
HP Smart Array SCSI
Adaptec AIC7xxx (New Driver)
Adaptec AIC79xx U320
Adaptec AIC94xx SAS/SATA
Marvell 88SE64XX/88SE94XX SAS/SATA
LSI Logic New Generation RAID Device (MEGARAID_NEWGEN)
LSI Logic MegaRAID SAS RAID
HighPoint RocketRAID 3xxx/4xxx Controller
IBM ServeRAID
Intel(R) C600 Series Chipset SAS
Qlogic QLA 1240/1x80/1x160 SCSI
QLogic ISP4XXX and ISP82XX
VMware PVSCSI driver
PATA
ATI PATA (PATA_ATIIXP)
AMD/NVidia PATA (PATA_AMD)
CMD64x PATA (PATA_CMD64X)
JMicron PATA (PATA_JMICRON)
Marvell PATA (PATA_MARVELL)
Promise PATA 2027x (PATA_PDC2027X)
Intel SCH PATA (PATA_SCH)
CMD / Silicon Image 680 PATA (PATA_SIL680)
SiS PATA (PATA_SIS)
VIA PATA (PATA_VIA)
Winbond SL82C105 PATA (PATA_WINBOND)
ACPI
Fan (as module fan.ko)
AMD Opteron/Athlon64 PowerNow! (as module powernow-k8.ko)
HARDWARE MONITORING
AMD Athlon64/FX or Opteron temperature sensor (SENSORS_K8TEMP)
AMD Family 10h+ temperature sensor (SENSORS_K10TEMP)
AMD Family 15h processor power (SENSORS_FAM15H_POWER)
ASUS ATK0110 (as module asus_atk0110.ko)
Synology Hard Disk Monitor (SENSORS_SYNO_HDDMON)
  ¦ If you say yes here you get support for the Synology
  ¦ Hdd Monitor to monitor the hdds' presentation and to
  ¦ enable/disable the power supply of each hdd.
User avatar
Trantor
Re: XPEnology DS3612xs DSM 4.2 build 3202++ (repack v1.0)
Postby interested » 06 Aug 2013 20:09
Hi Trantor.
I Thank you for all the effort and time that you put into this.
After update:
- all basic stuff are still working (Restart, Shutdown, WOL, Package Centre, Intel® I217V - LAN, installed packages )
- all 6 x SATA3 disc are stil present
- did not lose any data (migrate)
- What I dont see any more is my UPS, I assume that USB does not work.
TNX again.
CASE: Lian-LI PC-V354/B, MB: Asus Gryphon, CPU: i7-4765T, DDR3: KHX16C9X3K2/16X, HDD: 6 x WD30EFRX, PSU: SS-520FL, DSM: 6.0.2-8451 update 9
User avatar
interested
Postby FrankGNL » 06 Aug 2013 20:27
So if i convert is to ESXi and passthrough my LSI card, will Spin down work then?
Thanks
FrankGNL
Postby wenlez » 07 Aug 2013 01:48
I want to try this on ESX5.1 but I always fail to converted the IMG image to VMDK. I'm really in the interest to have VT-d working and pass through all my hard drives to DSM.
Supermicro X10SDV (Xeon D1540) ITX
1TB NVME SSD + 2x 480GB SSD
150W AC-DC 12V power brick. 22Watt at idle.
wenlez
Postby FrankGNL » 07 Aug 2013 06:26
wenlez wrote:I want to try this on ESX5.1 but I always fail to converted the IMG image to VMDK. I'm really in the interest to have VT-d working and pass through all my hard drives to DSM.
Try using StarWind V2V Image Converter to convert IMG to VMDK for me it is working
FrankGNL
Postby FrankGNL » 07 Aug 2013 07:17
Instaling on ESXi 5 is working, but when i retsrat it it will give grub error 22.
I trun off the VM, replace the boot disk and aftre that turn it on again, but the setup will start again from the beginning
Synology assistent said configuration lost
FrankGNL
Postby Trantor » 07 Aug 2013 07:46
+1 for StarWind V2V Image Converter. It can convert IMG <-> VHD <-> VMDK
FrankGNL wrote:Instaling on ESXi 5 is working, but when i retsrat it it will give grub error 22.
I'm not an expert with ESXi, but have to take a look in ESXi thread viewtopic.php?f=2&t=558 ?
User avatar
Trantor
Postby yold » 07 Aug 2013 13:16
Good job !
Works great on Nvidio Ion :-)
yold
Postby yold » 07 Aug 2013 14:15
Can you tell me more about acpi / powermanagement ?
acpi-cpufreq is not loaded by default and i can't find cpupower tools.
Thanks you
yold
Postby OkiieDoe » 07 Aug 2013 14:16
passthrough Lsi 9211-8i in esxi 5.1 working well
OkiieDoe
Next
Return to Releases
x
