romeoz Posted August 3, 2013 Share #1 Posted August 3, 2013 I originally installed DSM 4.1 from the packages below. DSM_DS3612xs_2668.pat (83.4 MB) https://mega.co.nz/#!JF8xxTIC!XxrW-GYDB ... vCLIg7W6x0 SynoBoot_3612xs_4.1++.img (200.0 MB) https://mega.co.nz/#!4F0S0YQR!eAK8PhgGy ... InCEe0dmVc I migrated to 4.2 with these packages below. DS3612xs_3202-Repack.pat (94.3 MB) https://mega.co.nz/#!AQEAiLRA!RJhGcmBjb ... tTJxb0paNQ microserver-dsm-4.2.img (123.0 MB) https://mega.co.nz/#!cIUlkBpJ!EXro9g_hc ... WpBzzGK2_A I was able to keep all my files except the PEAR installation, but that was not hard to reinstall. I also had to reinstall the Bootstrap as it was deleted with the migration. Everything is up and running on 4.2. (I'm also running a Gigabyte EP45-UD3P Motherboard with Core 2 Duo Processor) Link to comment Share on other sites More sharing options...
demayod Posted September 24, 2013 Share #2 Posted September 24, 2013 Are you able to use the yellow sata ports for your storage drives using the ep45-ud3p? Link to comment Share on other sites More sharing options...
demayod Posted September 25, 2013 Share #3 Posted September 25, 2013 I also have the EP45-UD3P. For the initial install of 4.2 I had to put my drive on one of the purple ports. If I used yellow, the install would complete, but it would hang when I would reboot. If memory serves me, it would get stuck when looking for AHCI drives during bootup. Is this something I'm doing wrong in the BIOS settings? When I installed using the drive plugged into one of the purple ports, install and startup would go without a hitch. I only have one drive in the system (just as a test). I would Like to use the yellow ports so I'm not limited to two drives in raid. -Any help would be appreciated. I'm very new to RAID but we have multiple synology DS1812+ at work. Thanks, Dan Link to comment Share on other sites More sharing options...
