lilobzh Posted February 26, 2017 Share #1 Posted February 26, 2017 (edited) RAPPEL IMPORTANT : ALPHA => EN TEST. A NE PAS INSTALLER SUR UN SERVEUR EN PRODUCTION !! * vous etes avertis comme ca Hop Version : v1.02a Version : v1.02a2 (correction bug DS3617 et DS916+) http://www.sendbox.fr/8822932d472692a4/V1.02a.zip https://mega.nz/#F!BtFQ2DgC!JgomNP3X8V9 ... g!5kcjyJ7R ALPHA => EN TEST. A NE PAS INSTALLER SUR UN SERVEUR EN PRODUCTION !! Uniquement pour CPU intel pour le moment Edited March 22, 2017 by Guest Quote Link to comment Share on other sites More sharing options...
lolvince Posted February 26, 2017 Share #2 Posted February 26, 2017 je procède à un test. migration d'un 6.0 (quicknick) vers 6.1 (Jun's 1.02)... migration, installation en mode manuel du fichier "DSM_DS3615xs_15047.pat" install OK reboot OK loggin to DSM OK volume EXT4 raid 5 (5x 500GO HDD) OK Données sauvegardés OK MAJ applis OK tout est ok pour moi ... attention passage de SurveillanceStation vers 8.0.1-5128 patch non disponible pour cette version il me semble... Quote Link to comment Share on other sites More sharing options...
lilobzh Posted February 26, 2017 Author Share #3 Posted February 26, 2017 Les mises a jour de DSM et de SSTation sont separées non ? Tu as mis tout a jour en meme temps ? Quote Link to comment Share on other sites More sharing options...
lolvince Posted February 26, 2017 Share #4 Posted February 26, 2017 oui j'ai tout mis a jour ... peu importe cela est une machine de test ... Quote Link to comment Share on other sites More sharing options...
lilobzh Posted February 26, 2017 Author Share #5 Posted February 26, 2017 ah oki ^^ j attend le patch amd du coup ^^ Quote Link to comment Share on other sites More sharing options...
lolvince Posted February 27, 2017 Share #6 Posted February 27, 2017 rien en vue pour SStation 5128 ? Quote Link to comment Share on other sites More sharing options...
anto62 Posted February 27, 2017 Share #7 Posted February 27, 2017 je procède à un test.migration d'un 6.0 (quicknick) vers 6.1 (Jun's 1.02)... migration, installation en mode manuel du fichier "DSM_DS3615xs_15047.pat" install OK reboot OK loggin to DSM OK volume EXT4 raid 5 (5x 500GO HDD) OK Données sauvegardés OK MAJ applis OK tout est ok pour moi ... attention passage de SurveillanceStation vers 8.0.1-5128 patch non disponible pour cette version il me semble... Bonjour lolvince peut tu me dire lors de l'utilisation de OSFMount quelle partition a tu prise. cordialement Quote Link to comment Share on other sites More sharing options...
lolvince Posted February 27, 2017 Share #8 Posted February 27, 2017 je n'ai pas utilisé OSFMount ... j'ai copier synoboot.img avec Win32DiskImager sur une clé usb, et j'ai remis mes paramètres propre à ma config dans le grub. Quote Link to comment Share on other sites More sharing options...
mister-chikite Posted February 27, 2017 Share #9 Posted February 27, 2017 Bonjour, Du coup pour le "DS3617xs 6.1 Jun's Mod V1.02-alpha", le DSM passe en X64, ainsi que 4 core ? Quelqu'un l'a essayé ? Merci d'avance Quote Link to comment Share on other sites More sharing options...
lilobzh Posted February 27, 2017 Author Share #10 Posted February 27, 2017 DSM 6 est déjà en 64 bits ? Pas compris les 2 fichiers à vrai dire. Quote Link to comment Share on other sites More sharing options...
mister-chikite Posted February 27, 2017 Share #11 Posted February 27, 2017 Si on regarde les spécificité du DS3617xs : https://www.synology.com/fr-fr/products/DS3617xs#spec On peut voir qu'il est en X64, je rentre et je test sur un PC hors prod Quote Link to comment Share on other sites More sharing options...
lilobzh Posted February 27, 2017 Author Share #12 Posted February 27, 2017 le 3615xs a un Intel Core i3-4130 (Dual-Core) qui est un CPU 64 bits a priori Quote Link to comment Share on other sites More sharing options...
mister-chikite Posted February 27, 2017 Share #13 Posted February 27, 2017 Re-Bonsoir, Je viens de tester les 2 Loader (DS3615xs et DS3617xs) J'ai réussi seulement a faire marcher le DS3615xs. Pour le DS3617xs j'ai comme message : "Echec de l'installation du fichier, le fichier est probablement endommagé". Voila pour moi. Bonne soirée. Quote Link to comment Share on other sites More sharing options...
Florian83260 Posted February 28, 2017 Share #14 Posted February 28, 2017 Salut à tous ! Le DSM 6 en version stable est donc en approche ?! En espérant que l'installation soit aussi simple que pour DSM 5.2 avec la clef USB ! J'utilise une carte J3710-ITX, pensez-vous que les drivers seront pris en charge ? Merci =) Quote Link to comment Share on other sites More sharing options...
stefauresi Posted February 28, 2017 Share #15 Posted February 28, 2017 Re-Bonsoir,Je viens de tester les 2 Loader (DS3615xs et DS3617xs) J'ai réussi seulement a faire marcher le DS3615xs. Pour le DS3617xs j'ai comme message : "Echec de l'installation du fichier, le fichier est probablement endommagé". Voila pour moi. Bonne soirée. Question bête mais tu as bien pris le .PAT du DS3617xs sur Synology.com ? Quote Link to comment Share on other sites More sharing options...
Jotouriste Posted February 28, 2017 Share #16 Posted February 28, 2017 La maj n'ai plus dispo ? Quote Link to comment Share on other sites More sharing options...
mister-chikite Posted February 28, 2017 Share #17 Posted February 28, 2017 Re-Bonsoir,Je viens de tester les 2 Loader (DS3615xs et DS3617xs) J'ai réussi seulement a faire marcher le DS3615xs. Pour le DS3617xs j'ai comme message : "Echec de l'installation du fichier, le fichier est probablement endommagé". Voila pour moi. Bonne soirée. Question bête mais tu as bien pris le .PAT du DS3617xs sur Synology.com ? Oui oui biensur avec le .Pat officiel Ds3617xs, as tu tester de ton cotés ? Quote Link to comment Share on other sites More sharing options...
anto62 Posted March 1, 2017 Share #18 Posted March 1, 2017 je n'ai pas utilisé OSFMount ...j'ai copier synoboot.img avec Win32DiskImager sur une clé usb, et j'ai remis mes paramètres propre à ma config dans le grub. Merci pour la réponse Quote Link to comment Share on other sites More sharing options...
stefauresi Posted March 1, 2017 Share #19 Posted March 1, 2017 Re-Bonsoir,Je viens de tester les 2 Loader (DS3615xs et DS3617xs) J'ai réussi seulement a faire marcher le DS3615xs. Pour le DS3617xs j'ai comme message : "Echec de l'installation du fichier, le fichier est probablement endommagé". Voila pour moi. Bonne soirée. Question bête mais tu as bien pris le .PAT du DS3617xs sur Synology.com ? Oui oui biensur avec le .Pat officiel Ds3617xs, as tu tester de ton cotés ? je ferais des tests en fin de semaine , car là j'ai pas le temps avec le boulot. Quote Link to comment Share on other sites More sharing options...
Cyangelizer Posted March 1, 2017 Share #20 Posted March 1, 2017 Hello! Le liens vers mega et indisponible... vous croyer que la version stable mettrais longtemps a arrivés? je me demande si ça me permettrais d'étre plus stable sur ma machine avec le DS3617 :3 Quote Link to comment Share on other sites More sharing options...
mister-chikite Posted March 1, 2017 Share #21 Posted March 1, 2017 Voici un Wetransfert avec le version de june en Alpha. https://we.tl/6yGihDLUi7 Pour le moment c'est qu'une version alpha, aucune date n'est prévu pour la release version. Quote Link to comment Share on other sites More sharing options...
Cyangelizer Posted March 2, 2017 Share #22 Posted March 2, 2017 Voici un Wetransfert avec le version de june en Alpha. https://we.tl/6yGihDLUi7 Pour le moment c'est qu'une version alpha, aucune date n'est prévu pour la release version. Je te remercie c'est gentil ! je m'occuperais de ça une fois mes téléchargements terminée Peut étre que certain de mes soucis seront corrigés grace au 64b Je vous tiens au jus! Quote Link to comment Share on other sites More sharing options...
F5BJR Posted March 3, 2017 Share #23 Posted March 3, 2017 (edited) La version DS 3615XS s' installe et fonctionne avec mon QNAP TBS-453A La version DS 3617xs ne s' installe pas -> Erreur fichier pat incompatible ??? Pour information c' était juste un test car le firmware QNAP a bien plus de fonctionnalités sinon ce superbe petit joujou fonctionne aussi très bien avec Windows 10 et +++ Edited March 4, 2017 by Guest Quote Link to comment Share on other sites More sharing options...
Jotouriste Posted March 4, 2017 Share #24 Posted March 4, 2017 moi ça marche impec sur le N54l en ds3617xs et pareil sur Nas Custom i3! juste un message sur les disques à chaque reboot ! Quote Link to comment Share on other sites More sharing options...
babeuloula Posted March 5, 2017 Share #25 Posted March 5, 2017 Ah cool, j'ai hate que la version finale sorte. Il y a une date ou pas encore ? Quote Link to comment Share on other sites More sharing options...
